pvc cutter
  • pvc cutter
    look at what i have in my hands
    it's a milwaukee 12 volt pvc cutter 2'' capacity.
    this is about as close as i will be to owning 1
    personally cutting pvc is not a difficult task. maybe if i did alot of sprinkler or pool work, i might buy 1, but i don't see a need to spend $200 on a pvc cutter.
    pvc cutter with demo plastic clear guard installed.
    don't waste your money.
    Re: pvc cutter
    I bet if it said Ridgid on it you would own one *grins* I could use one for cutting the pvc in tight chases and such. But other than that I do not need one. Yet.
      Re: pvc cutter
      ron, you know what we looked at the roundup
      i said it was a waste of money.
      same thing here.
      rick
        Re: pvc cutter
        True. I guess like you said for pool installers and such its a useful tool to save some time. As a service plumber It only can help to gut the pipe with ease and straight in them tight spaces. But for 200 bucks I rather spend the extra few minutes with a reciprocating saw that I already own.
        same thing here.
        rick
          Re: pvc cutter
          Rick, will it cut ABS?
            Re: pvc cutter
            not according to the website. it only refers to pvc and pex. nothing mentioned abs
            http://www.milwaukeetool.com/Product...ordless+System
            i pulled up the owners manual and found the specs. page 5 shows 2'' abs pipe.
            pretty poor advertising when you have to look at the owners manual to see if it will work.
            http://www.milwaukeetool.com/CMS/Dia...-14-2475d2.pdf
              Re: pvc cutter
              They put that demo guard on just for you Rick... remember PHC Long Beach 3 years ago
                Re: pvc cutter
                http://www.youtube.com/watch?v=zlX8lgSk6Jo
                I've owned the ratcheting type of cutters back in the day, thought it was great but I don't live in year round warm climate. That has a HUGE determining factor when it comes to PVC pipe when you cut it.
                I've had both SCH40 and tubular PVC explode when cutting. If it is hot out, warm weather? Cuts like a hot knife through butter like the video is showing.
                They'll sell a ton of those to new construction plumbers. Looks about the fastest way to cut plastic, even small pieces for hub to hub close tolerance pieces.
                  Re: pvc cutter
                  josh, i did that to mark my territory and i did bleed ridgid red
                  what's funny is their copper cutter at h.d. has a demo plastic guard on it too
                  what's next, the led flashlight with a protective welding hood
                    Re: pvc cutter
                    Rick, that PVC cutter is an awesome tool. I have used mine for several weeks now, and it really saves time and wear and tear on the hands.
                    I can see for the type of work that you do that it would be almost useless, just like a ProPress tool would probably gather dust on my truck.
                    I would highly recommend the tool to anyone that has to deal with PVC water lines on an almost daily basis.
                    It also cuts ABS pipe.
                      Re: pvc cutter
                      Put a man on a chop/mitre saw and call out measurements like your life depends on it.
                        Re: pvc cutter
                        If it was just a little larger on the capictiy, I would love it. I just had a fight with my Ridgit ratchet cutter demoing old 2.5" chlorine lines that tended to shatter rather than cut. Chlorine+skin=bad.
                          Re: pvc cutter
                          whats funny is the managers in ricks area know to install guards on all tools
                          just left hd and no guards in ohio--must figure with ridge around the corner the ohio plumbers know what they are doing
                            Re: pvc cutter
                            Absolutely this. the pipes get cut as fast as the helper can run the chop saw.
                            [/B]
                              Re: pvc cutter
                              another option is dewalt's cordless angle grinder with a cutting blade.
