Adding shear rings to existing Fernco?
  • Adding shear rings to existing Fernco?
    I have a 4 in. ABS waste stack that connects to a 4 in. cast iron pipe coming out of the concrete basement floor using an unshielded Fernco coupling. I have not removed the Fernco to look at the pipes but I suspect they two pipes aren't cut flush with each other since there is some play in the connection. Is it possible to purchase and add a metal shield to this Fernco to make sure the pipes stay alligned or do I have to replace the Fernco with a new one?
    It would be convenient to just get something like a shear ring and put it around the middle of the Fernco...assuming that can even be done.
    The reason I ask is that this pipe will be behind a new false wall as part of a basement remodel. The wall will have an panel to allow access to the waste stack's cleanout. I just want to make sure I don't need to worry about the ABS to Cast connection after the wall is up.
    Any comments would be appreciated.
    Re: Adding shear rings to existing Fernco?
    i would remove it and put on the proper connection. a shielded transition band and make sure the ends are cut correctly.
    it may be fine, but if ya know about it why not fix it? and be done
      If it were as simple as sliding the old one off and sliding on a new one I probably would. I just doubt there is four inches of give in the stack to get the new one on. I'd have to cut the ABS and put in a new section which would include putting in a new leanout and a new 2 inch T. I guess that's doable, just more work than I had hoped. Sure would have been easy to just add a shearing section
