What is the best ridgid propress maciine
  • What is the best ridgid propress maciine
    what is the best propress machine to have. I'am thinking of buying one .Ijust tring to pick the best all around to have.
    Re: What is the best ridgid propress maciine
    Wait for Rick to respond.............
      if you're only going to do 1.25'' and smaller, then the rp 210-b would be the way to go.
      but if you want to press 1/2''- 2'' and 2.5''-4'' then either the rp 330-b cordless or the 330-c corded unit will be great.
      the older units 100 and 320, and 400 are the older units that are discontinued. a deal could be found on those if you want to save some money.
      fortunately, i have excess stock
        Ok,so what would the a good price be for a good used propress tool be.
          depends on what you consider a good price and a good machine.
          all of the machines have an internal computer that counts the cycles among other things. the 400 is a beast and it doesn't have all the electronics.
          a propress either has a 20,000 or 30,000 cycle interval before it needs service. unless you have it looked at by a factory service center with a propress computer, you really don't know what you're getting.
            Used 100 machines are $500 to $800 depends on hours and what jaws you get jaws are not cheap! 320's go $900-$1200 again depending on what jaws and how many hours and the 400 corded machines are about the same price maybe a few hundred more.
            Seattle Drain Service
              thanks now I have an idea of what I need
