2" stainless steel pipe threads
  • 2" stainless steel pipe threads
    hello, I was doing some fitting today with 2" pipe, some of the threads were made at a shop for me but others I made myself with a rigid ratchet threader and the stainless steel dies, but halfway through the job( about 50-55 nipples) I threaded somoe nipples in hand tight to get a measurement and they just seized in there I used a 36" RIGID pipewrench and a 5' snipe but just ended up egging the niplles any ideas? this is my first picnic with stainless but have done lots of carbon steel fitting. thanks
    Re: 2" stainless steel pipe threads
    Some SS does not play well with others even on factory threaded nuts and bolts. Put some dope, tape, never seeze, or what ever on them to prevent them from galling up on you. Once they gall up you are screwed.
      Worked with SS piping back in the late '60's-'70's at a textile mill. The older pipe fitters taught me that " get it right the first time--or be screwed", no pun intended. SS is a breed to itself. David
        this is true with SS i had some nuts and bolts that i put together hand tight and they would not come apart , i had to cut them to get them off .
        try some pipe dope even if your taking it apart ,i used never seize
          Give Us an Address, Tozz and I will weld it for You . Then You won't be SCREWED !
            antiseize is the only thing i have found to help assemble stainless bolts without galling . but to pipe threads i would probably put a thin coating on the threads and "dry" fit . clean off then followed by the thread sealant of your choice.
            Larry
              OK! Guys, It's rare that I'm not in total agreement with "Tozzi", But, Stainless does not gall, or "gælle" (fish-gill in Danish). On the contrary, it mirror polishes, and that's where the problem starts. You know what happens if you glide 2 surfaces of clean plate glass together? Yeah! they kind of fuse, and almost weld together. Stainless can be mirror polished, and that's exactly what happens. The nicer the threads you made are, the worse it gets.
              Any threads in stainless, regardless of factory made bolts etc, or self cut threads must be lubricated. What you use is not that crittical, That you use something is. Never-Sieze, etc, is of course optimal and excellent, and so is a lot of other stuff.
              I hope this helps to avoid some unnescessary problems!
