a good day next Monday
    Re: a good day next Monday
    charlie, you have my #
    call me for details.
      Originally posted by JW3 View Post
      how often are you going to use the machine???I bought a corded unit,reason being that there are times the propress sits for a wk or 2 without work.(I only use it on repairs)Nothing ticks me off worse than a cordless battery dying on me in the middle of something.If you are going to use it alot tehn buy cordless with a back up battery. Just my 2cents.
      Power tools in general I feel the same way. My cordless have their place but 90% of the time if I have access to an outlet I will use my corded tools.
        ok it was not a ridgid rep it was a Rems rep and also selling Elkhart fittings
        the tool was heavy and was only a 12v
        now is it true when you crimp a Viega fitting the pipe inside the fitting gets all bent up but the Elkhart fittings dont do it ?
          [QUOTE=HVAC HAWK;287211]ok it was not a ridgid rep it was a Rems rep and also selling Elkhart fittings
          now is it true when you crimp a Viega fitting the pipe inside the fitting gets all bent up but the Elkhart fittings dont do it ?[/QUOTE]
          1.5'' -2'' there is a noticeable crimp. nothing i would worry about as i have a good 6 year + track record with these fittings with 0 failures. this i know for a fact
          the ridgid propress jaws will press all the brands of fittings. 1/2''-2'' not sure about the 2.5-4'' as viega is all i use.
            i know you have a good track record but does the crimped pipe effect flow and why do you get this with the other fittings
            i will call you some time soon ,dont call my work ## just my house
              no dosnt effect flow and the corded p.p tool we have stays straight were the cordless head turns 45deg to get into tighter spots
              SMELLS LIKE $$$$$$ TO ME
                the original 400 corded propress didn't have a swivel jaw head. but the new corded 330 is identical to the 330 cordless in that the head will swivel 270 degrees.
                of course you could always get the propress rings that allow for a swivel offset.
                between the swivel head and swivel jaws, there's a position for every tight application.
                • #23
                  Not sure how much copper you are working with, but once you have the tool, it won't be sitting long enough to have the batteries just run down.
                  The system is amazing and I just get so happy when I get a job big enough to rent one.
                  My avatar, is every mans wet dream, don't lie. We all know you ride the bedroom moped
