1822 threader
  • 1822 threader
    I have an issue with an 1822 power threader with a universal self opening die head.
    When threading various sizes with both heads 1/2 to 2" and the head set at exactly the mark on the size bar, the finished threaded pipe threads are oversized.
    What can be done to fix this problem. We have alot of different people using this threader and would like to beable to set the size and run it, not set size test test then thread the piece.
    The dies seem to look excellent shape, was told the cam cannot be worn or it would be cutting the threads to much... just looking for any advice
    Thanks
    Re: 1822 threader
    you need to adjust your setting and loosen them up a little to cut a little less deep.
    the head has an adjustment that puts you very close. a little fine tuning is what it takes.
      Re: 1822 threader
      But it is not cutting deep enough currently, the pipe thread diameter is a little bit to big after threading
      what adjustments do you mean?
        Re: 1822 threader
        http://www.ridgid.com/ASSETS/A289959...ie_Head_PL.pdf
        adjust the lever tighter to cut deeper. turn it slightly towards the smaller size on the cam plate. then lock it in place.
