Propress for heating systems
  • plumberscrack
    Re: Propress for heating systems
    Originally posted by HVAC HAWK View Post
    thanks i think the job we are looking to use it on is just water at about 180*
    It's used here all the time for heat work. Saves you not having to sweat big fittings on a changeout. Water will drip out of a large heat main for a few hours making it harder to sweat. As long as it's not used on a steam system, temperature shouldn't be a problem. I would caution against using cleaning chemicals like Boiler Colloid with Propress fittings.
  • HVAC HAWK
  • Lee H
    Not so good for systems with glycol, the seals leak discoloring the pipe and fittings, it doesnt look so good.
  • HVAC HAWK
    thanks i was looking for that yesterday
    has any one used the fittings for heating systems ,what do you think
  • BobsPlumbing
    Page 12 here gives you a table or working pressures & temperatures for different applications:
    http://www.viega.net/cps/rde/xbcr/en...Pocket0208.pdf
    Good luck.
  • BobsPlumbing
    According to the handbook from their website:
    Hot and Cold potable water: 32F-250F at 200PSI with the "shiny black EPDM seal".
  • HVAC HAWK
    started a topic Propress for heating systems
    what is the temp limit for the fittings that would be used on a boiler system
    we have a job coming up and the boss asked if propress would work for this ,it will be 2" and 2 1/2 " copper . i said it would be a lot faster then soldering . so im hopping he goes for it
