Cutting 4" Stainless Steel
  • Cutting 4" Stainless Steel
    what's up guys? I'm noo. nice forum. I have a job coming up that requires some 4" SS fabrication and I need to know the best way to cut it. I did a search of the board and the only thing I could find was the 35S, which won't work on pipe up to 4". help, please. thanks.
    Re: Cutting 4" Stainless Steel
    Get a wrap a round, mark it square, then use a whizz wheel in a 4" grinder. If your good you can get a nice square cut with your Porta Band too, just make sure you have a SS blade in it.
      ridgid sells a drycut chop saw. uses a carbide tipped sawblade that cuts fast with no heat and next to no sparks.
      i have the dewalt version and i cut steel with it with great results. don't have a stainless blade since i don't work much with stainless.
        You mentioned the chop saw AND the blade. The blade is the 71692, right? Is the chop saw a low RPM or something special, or can the blade just drop in a different chopsaw?
          Originally posted by TozziWelding View Post
          If your good
          that rules me out.
            ....and thanks to both of you.
