pro press question
    Re: pro press question
    no need to remove a pressed fitting as i've never had a leaker.
    tell me you never had a leaker on a copper line especially with water present
    Oh, I've definitely had a leaker, just as I'm sure you have. Don't know what that has to do with the OP's situation though in relation to rotating a solder joint vs. rotating a press joint.
      Rick after you crimp the fitting it makes it so it has 6 sides and is not round correct
      and you say you can turn this fitting after it went through a full crimp ?
        the larger fittings 1.5''-2'' will show a hex much more than the smaller ones and xlc fittings.
        of course the smaller fittings are easier to rotate than a larger fitting. it's more of tweaking it into position than rotating it into position.
        charlie, you sure you don't want me to do a job site show and tell. i promise i won't sneak up on you
