having problems with ridgid 700
  • having problems with ridgid 700
    Having problems rigid 700 theater my half head model 12 r did not cut the treads correctly the steel from the cutting is getting into the path of the cutter teeth. And the new treads and messing them up I bought new teeth but am still having the same problem any suggestions
    Re: having problems with ridgid 700
    How's your oil?
      Using new oil on a spray bottle rigid brand
        Spray bottle is not enough volume.
          So I should use more oil to get the thread cuttings away from the teeth
            Your dissipating heat.
              die head needs dies adjusted. easiest way is to loosen the 4 phillips screws and thread the die head onto a factory nipple a few threads to set the dies. then tighten the screws.
                sometimes new dies need to be used coulple of times than work better
                  Plumber Rick is correct.
                  When you purchase new dies for the 12R heads you need to keep the screws a little loose, then thread the die head onto a piece of pipe already threaded to satisfaction. Then while the die head is still on the pipe tighten up the screws, also it is always a good idea to double check that the dies are in the correct spot ie: #1 die in #1 slot and so on.
                  let us know if you have any questions
                  http://www.tradetoolsupply.com
