Propress repairs question
  • Propress repairs question
    My 100b started blowing oil out the snout today. Anybody had this happen and how much am I looking at for the repair if anyone has had this repair done before. And I didn't have my 1 inch manual tool near where we where working so I had to bite the bullet and go buy another 1" manual crimper to get the peoples water main back on line. I will never not have a backup up again with us.
    Thanks in advance!
    Seattle Drain Service
    Re: Propress repairs question
    So far mine has not needed any repairs. Maybe Marvin has seen this. I might be heading there tomorrow I will ask then.
      I had heard not to store it in cold temps, I was using it in about 39 degrees I don't know it thats too cold?
        If I know I am going to use it the day before I bring it in the night before to keep it at room temperature.
        But I have pulled it out of my truck during 15º days and had to let it warm up a little before it let me turn it on and press.
          I always cycle it not under load then start using it but this time it did not crimp and oil came out on the jaws. And this was pex not copper.
            Is that suggested by the manufacture through literature Ron,or word of mouth?
            Sorry bout your tool Cuda.
              Marvin told me about keeping the tool inside the night before when I was renting his ProPress system. Not sure if its in the literature. I'll go to the van now and grab the instructions.
                I find that many of my battery tools work better when warmed rather than left in the truck and it's freezing cold. And/or ran a little to "wake up". Regardless of battery chemistry.
                  No Dang-it!!!
                  It ain't that important.
                    I've even noticed it out here on a cold couple of mornings it got down to the low 40s
                      The instructions just state how the batteries need to be at least 15º or warmer to work properly. Also the tool temperature sensor will not allow the tool to turn on if oil temperature is not within the temperature range of 0°F (-20°C) to 104°F (40°C).
                        Talked to Chris at A J Coleman, he is the guy there that does simple repairs on the ProPress units. He said there is a bladder in there that might of split. It could cost around hundred bucks to fix. But if it needs calibration he can not do that there. There is some sort of computer they have to use to calibrate the unit and only authorized Ridgid Service Centers that have that computer or you have to send it to Ridgid.
