Pro Press on soft copper
  • Pro Press on soft copper
    i had my daughter text jo jo to ask the pro and jo jo said it was of on soft copper ,not that i dont believe her but i just what to see if any one ever had any problems with it
    Re: Pro Press on soft copper
    I press right thru a 50 yr old water service today! I was there to replace the main valve and after I turned the water back on I went back into the basement to check for leaks and the 90 was leaking at the connection to the soft copper . I would post the picture I have on my Droid as I am still working but don't know how.
      hope you get it to stop
        it looks like it was a weak spot maybe flux or the crap that they put in our water out here . When I looked in pipe I saw a chunk of something when I touched it it fell out and then I could see the fitting. I reamed the new cut and repiped every thing. I stayed their for another 30 min. And it never dried. I think I may start using pex for small repairs more.
          it's approved up to 1.25'' soft. i think the biggest issue is that the soft copper is not typically round when you unroll it.
          glad you got it. next time cut out the middle men and speak right to the boss. you got my #. remember ricky don't loose that number, it's the only one you got
            I ll post the pictures when I get home . Just got done cutting ten feet off a well pump line .
              rick i had my work phone when i need to know because i was ordering fittings for a job that im cutting out old heaters where the main lines are above and i wanted to press valves on and not have to wait for the water to stop .
              so i had becky text jo jo and we were good to order ,thanks jo jo
              i dont thing my boss would like me calling long distance with there phone
