Residential 358
  • #31
    Re: Residential 358
    Originally posted by spoon View Post
    What violation would that be ?
    Metal strap touching plastic pipe.
    • #32
      Re: Residential 358
      You mean you can't use hanger iron anymore on PVC, ABS, etc.?
      • #33
        Re: Residential 358
        Metal pipe hangers should be insulated from touching plastic pipe. In a hanger the pipe can expand and contract more freely than a two hole strap against a concrete wall. Codes differ from area to area....so it may or may not apply to everyone.
        • #34
          Re: Residential 358
          I'm on the UPC here. I believe the theory concerning expansion and am confident the offset will counteract any expansion.
          • #35
            Re: Residential 358
            If your satisfied with it then I am too.
            • #36
              Re: Residential 358
              ...and so Master are you saying that the metal strap can cut into the ABS pipe? Is that the reason ?
              • #37
                Re: Residential 358
                I guess thats the thinking ..I hate using that cheap as* plastic strapping ..I use strap iron
                • #38
                  Re: Residential 358
                  Thanks. B. V.'s are an owner request. Ceiling isn't finished.
                  Excuse the ignorance, but what does B.V.'s stand for?
                  Thanks.
                  • #39
                    Re: Residential 358
                    I guess riser clamps are out of the question. and no I was never an electrician.
                    • #40
                      Re: Residential 358
                      Thanks.
                      Ball valve.
                      • #41
                        Re: Residential 358
                        It damages the pipe wall.
                        J.C. B.V.'s= Ball valves
                        • #42
                          Re: Residential 358
                          Curious how you'd support a waste stack in a three story building ?
                          • #43
                            Re: Residential 358
                            Thanks, I did not see them. I don't believe a situation will ever arise for that clamp to damage the walls of that pipe. Maybe earthquake.
                            Then it would probably hold better anyway. Yin and Yang.
                            • #44
                              Re: Residential 358
                              Riser clamps Do they make plastic riser clamps for plastic piping ?
                              • #45
                                Re: Residential 358
                                You would need to seperate the metal from the plastic with an insulator....such as rubber.
