Hanging Chad
  • Hanging Chad
    does your Pro Press do this its a 1/2" fitting and it does it on every size up to 2 "
    [IMG][/IMG]
    [IMG][/IMG]
    Re: Hanging Chad
    Rick...................
      Re: Hanging Chad
      it does, but not near as bad.
      as you know each jaw is hand fine tuned and polished. each one is tested and documented.
      i would have to compare my 1/2'' crimps to your photos and see the results.
      have you used the scotchbrite pad to clean out any buildup in the jaws?
      the joints are water tight, correct
        Re: Hanging Chad
        Looks hideous....Almost looks like the wrong jaws are being used
          Re: Hanging Chad
          [IMG][/IMG]
          [IMG][/IMG]
          Mine does EXACTLY the same thing 3/4" - 2". Some jaws seem to be worse than others. I've actually gotten some decent size scratches on my hands and arms from these protruding shims when I'm working nearby and reaching over the pipe or fitting. I never thought about it, but maybe this is a warranty issue. After all Ridgid isn't bashful about charging for the device.
            Re: Hanging Chad
            actually ridgid was thinking about us plumbers with this feature.
            they accomplished 2 of the 3 plumbers rules and actually improved on them.
            since we were always told not to chew our fingernails, they designed a nail scraper built into the pressed fitting
            and the old rule of paydays on friday, has been drastically improved.
            every time i use my propress or any other ridgid tool, it's payday
            now if they could only make pooh go uphill
            charlie, i'll try doing some test with different jaws and fitting brands.
            is 1/2'' the worse. what machine are you using? the 210 or 330 using the jaws or swivel rings?
            just for you charlie
              Re: Hanging Chad
              Built-in press indicator for low visibility areas?
                Re: Hanging Chad
                this is the 2nd time using the 210 and pressed about 80 joints with it ,it did it the first and the same all the time . i just run a file over it and hope mot to forget so no one gets cut from it
                yes it is water tight never had a leak yet
                i have not used the 1/2 with the 330 yet but it does it with all the jaws i have used with the 330
                  Re: Hanging Chad
                  no not yet i only crimped about 80 joints with it and it is very clean
                  of course its a Pro Press with Viega fittings
                  i just want to make sure there is nothing wrong with it but if it happens with all my jaws then thats the way it is
                    Re: Hanging Chad
                    Ours does it too
                      Re: Hanging Chad
                      thanks every one
                      i just have to make sure i dont get cut on one now
                        Re: Hanging Chad
                        Your Propress Jaws probably need cleaning. With regular use, it is common for jaws to develop a buildup of fitting material near the jaw tips. Therefore, Jaws should be regularly inspected and cleaned. I have attached a copy of the procedure for your reference.
                          Re: Hanging Chad
                          What's the safe distance for soldering a joint next to a propress joint?
                            Re: Hanging Chad
                            steve, typically i solder first, then press the joint.
                            if not, then you need to keep the o-ring cool enough with a cold spray or damp rag. not sure if there is a given distance.
                              Re: Hanging Chad
                              the tool is new and may have only 15 joints with it ,it did it on all heads from day one
                              thanks for your response
