Over and Under Page Title Module
  • Over and Under
    Do you adjust for Over and Under? Situations?
    Thanks.
    Re: Over and Under
    Thanks.
    Not sure ..it really depends on the situation ..Over
      Re: Over and Under
      Threading die.
        Re: Over and Under
        Did Mommy give You a Dick Tracy Code Book ?
          Re: Over and Under
          No.
          A diehead has an "over" and "under" compensation built into it. I was curious as when others use it, if ever, and what situations. And if it could possibly help them if they did start to recognize this feature to decrease a percentage of problems that may arise with certain materials.
          I'm not smart enough for a Dick Tracy Code Book.
          Thanks.
            Re: Over and Under
            I thought it was used to compensate for die wear *shrug*
              Re: Over and Under
              Recently, while threading 3" gal for starter nipples coming out of Zurn scupper drains we had to adjust the die head so that the threads would cut a little deeper than a normal malleable fitting would require because the nipples would only hand thread into the drains a half turn before a wrench was required and we knew that a water tight seal would be impossible to achieve. The reason for the gal nipples was because the 7" Zurn nipples were too short for our application.
                Re: Over and Under
                Bill
                Compensating for die and diehead wear is a pita, especially when many people are using the same threader.
                  Re: Over and Under
                  Then why the under? Have to confess that I've never really messed with it. Thought I might be able to improve connections if I learned from ya'll folks.
                    Re: Over and Under
                    Cool.
                      Re: Over and Under
                      Thanks.
                      JC When you're compensating pipe threads for tight or loose fitting (FIP) threads the "over" and "under" are the opposite of what a body would think. If you want the MIP threads to have a larger diameter you under cut them. If you want them a smaller diameter you over cut them.
