Ridgid 1233 threading machine
  • Ridgid 1233 threading machine
    i have a ridgid 1233 threading machine and was wondering if it re-circulates the cutting oil used. iv heard it does but it doesnt seem to work on my machine
    any advice appreciated
    stu rymer
    Re: Ridgid 1233 threading machine
    The RIDIGID 1233 Threading Machine is equipped with through die head oiling thus the oil is returned to the reservoir and recirculated.
    If oil is not flowing through the die head first check the filter at the bottom of the reservoir and make sure it is not clogged. You can check the filter by removing the hose from the rear of the filter as shown below then run the machine according to the opearting instructions.
    The oil filter is raised off the bottom of the reservoir so make sure the oil level is above the filter.
    On the carriage is an oil bypass, as shown below, make sure it is open.
Name:	Oil Bypass.jpg
    Other than the above please make sure the pump is functioning and that the oil is flowing through the die head.
    If the suggestions above don't resolve the problem, the oil system is clogged and needs to be cleaned or the pump may be in need of repair.
    Thank you for contacting us.
    RIDGID Product Manager
      May I know the machine dimension of 1233 Threader. Thanks.
