Stuck nipple in 819 chuck!
  • Stuck nipple in 819 chuck!
    Just tried the Ridgid 819 Nipple Kit with a 2" pipe and after cutting the thread it is stuck tight. The chuck release seems to be jammed? Does anyone know what I've done wrong???
    Re: Stuck nipple in 819 chuck!
    did you release the chuck when you initially put the nipple in? the release was designed to release the nipple when completed. have you tried a pipe wrench to back off the nipple yet?
      Sure I think that's why it's stuck fast! I tried to undo it with a 24" but only pulls the motor, don't want to grip a wrench on the chuck and cause damage. Gonna try when in work monday running motor in reverse. Fingers crossed it doesn't break the release bit.
      Mark.
