Welder
  • Welder
    Recommendations for a smaller MIG welder that is versatile for many things. I have no specific criteria to give to help narrow recommendations. Sorry.
    Just something that can cover several scenarios. Not a large professional rig but not a toy either.
    Just want to teach myself some.
    Lincoln?
    Hobart?
    Miller?
    Others?
    Models?
    Thanks.
    Re: Welder
    Bump.
    Thanks.
      Re: Welder
      I Like Hobarts, They where nice welders then Miller bought them out. They are still good they cost less then a Miller. A Miller would be my second choice. The only reason I don't like Lincoln's is because I never had good customer service from them. As for the model it matters if you will take it with you or will it stay at home? Try to buy on around the 175 size that uses 220. Or go bigger! Most people buy a 125 to start learning then switch up later just go bigger first and save some coin.
      Seattle Drain Service
        Re: Welder
        120 volt is easy to plug in and take with you.
        240 volt and you can weld some serious metal.
        i have both for shop and portable. along with the tig and arc and plasma.
        the 120 will work fine for your cable connections too.
          Re: Welder
          a number of years ago I bought my son a Hobart 140 MIG (I think it was this model) if not a for runner of it.
          FREE SHIPPING — Hobart Handler 140 MIG Welder — 115 Volt, 140 Amp, Model# 500500 | Wirefeed Welders | Northern Tool + Equipment
          we bought it through northern as they had a free shipping promotion at the time and actually got it cheaper than the welding shop could have bought it for (or that is what they said at the time),
          and he has used it a lot over the years,
          Miller and Hobart, are owned the same group, (and it is my understanding that the miller is like the Cadillac and the Hobart is like the Chevy).
          Hobart 140 vs miller 140
          one other thing that was nice with the 140 is my 3400 watt generator was able to run it on 120 volts, and will run off a good extension cord, so there is some portability with it as well, we put a bottle on it but did run with flux core some as well, he has done a lot of projects with it, (and has worked as a professional welder for a number of years before it started to affect his health), and he thinks it is a good welder for it size and features.
          I think if you keep in the name brands, (Lincoln, Hobart, Miller), they would all preform well,
          wire feed welders do at times need some maintenance, tips and liners and feed rollers, so you may want to look around to see what brands are supported by your local sources and consider that as well.
            Re: Welder
            since my son now has his own place and shop I had to get a welder for portable use, so this is what I came up with,
            The truck was given to me, it was more rust and looked like crap when I got it, (I repainted it in the shop) put a different bumper and grill guard on it, the bed was on it when I got it, (I did put a couple of receiver tubing sections in the bed so I can put different vices in the bed (one can see a pipe vice on it in the second picture), or other things, (for example: I have a wire roller that will set in the tubing in the bed as well for fence building),
            and the welder I bought used for few hundred, (It is a nice welder just a lot of Hours on it), and the torch is one I had, bought the leads off of Ebay, not a bad rig for the money I put in ot it,
              Re: Welder
              I grew up with lincoln stick welder. I have 2 hobart welders stick welder and mig 140. I use the stick welder for thicker metals. The 140 for thin material. If you use indoors,use the gas with the mig. You can not use gas outdoors in the wind.Thats where fluxcore wire comes in.Very versatile machine, easy to use.Hobart 140 is a welder you should have no problem learning to use. Check out welders forum for good advice if your just starting out.
              Huck
                Re: Welder
                Nice,clean rig! There's a lot of wisdom here for Us all. You make a buck go a long way! Wise,thoughtful,moves,with great results! A lost art.
                  Re: Welder
                  I'm an x Union welder,still weld for Myself. Go 220volts miller elec. mig. Get a bottle of C-25 gas. I have a 210 millermatic and lots more. GO BIG BLUE ! wish You were closer
                  I'm a good teacher. sign up for night and Sat. classes at a Jr. college.
                    Re: Welder
                    When you coming home? I second buying a bigger machine, you can turn a big machine down, you can't turn a small machine up.
                      Re: Welder
                      I may be home to take My Brother in law [ another Marine ,75] to the Nov. 10 th Marine Corps Birthday bash in Boston.
                        Re: Welder
                        JC PM sent, but your box is full.
                          Re: Welder
                          Lincoln PowerMIG 180 is my choice, and a Tomahawk 375 plasma cutter.
                          The 375 has its own air compressor, so its nice for portable work.
                          POWER MIG® 180 Dual MIG Welder
                          http://www.lincolnelectric.com/en-us...incolnElectric
                          John Ruskin (1819 - 1900)
                            Re: Welder
                            Deleted a couple.
                            Resend if you like.
                            Thanks
