10" Spool Piece
  • 10" Spool Piece
    A 10" spool on one of our pumps let go so I had to make a new one, 10" Sched 40, nothing fancy, the flow is 1600 GPM @ 110PSI.
    The parts
    The set up
    Next post
    Re: 10" Spool Piece
    6010 root
    5/32 7018 at about 200 amps out
    The slag just falls off
    Done and painted
      Re: 10" Spool Piece
      looks good. digging the flange bolt level.
      is it typical to weld inside the flange?
      i guess with pipe to pipe ends, you have no choice but beveling the pipe to allow for the root pass and full penetration.
      glad to see 7018 is still the rod of choice on the final pass. sure lays down a nice bead and easy clean up.
      does anyone attempt to mig the big stuff?
        Re: 10" Spool Piece
        Weld the inside so the product dosent get in there and cause a problem, there are some procedures for hardwire MIG, but not widely accepted. If I had a good dual shield wire in this plant I would have used the MIG, but whatever 4.5 hrs from cut to finish, most of it welding.
          Re: 10" Spool Piece
          Looks good. As far as welding the inside goes, I would imagine there is a substantial price difference between weld neck/slip on flanges?
            Re: 10" Spool Piece
            I use whatever parts they supply, so it dosent matter what they cost. Rick, if you are gonna buy a flange level like that go with FlangeWizard, they are still made in the USA. Mine is a Curv-O-Mark, sadly made in china now.
              Re: 10" Spool Piece
              I thought that was you over on weldingweb.com. It must be nice to just watch the slag practically fall off your welds. I dont know if its my skill level or just the cheap rods, maybe a combo of both.(lol) Hows the new truck working out for you? The deck on that thing looks more than useable.
                Re: 10" Spool Piece
                The new truck
                is working out great the crane and lift gate have saved my back so much. I don't know how I worked out of a pick up for almost 10 years.
                  Re: 10" Spool Piece
                  Nice beads,I love 7018
                    Re: 10" Spool Piece
                    nice work i like using slip on flanges so if things are not square you can make a little adjustment
                      Re: 10" Spool Piece
                      We made the same stuff back in spain so the increased quality of your work is very apperant. Looks great.
                        Re: 10" Spool Piece
                        When You,re welding every day, You,re always in the zone ! For Me I need to run some beads on scrap to get dialed in!
