Nibco Press Fittings
  • Nibco Press Fittings
    Anyone using them? Anyone used them in the past?
    Anyone?
    Bueller?
    Good, Bad, In-different. Would like to know.
    Thank you. Thank you very much.
    Re: Nibco Press Fittings
    I have used Nibco, they are ok, never had an issue. I used them in a pinch because they were out of viega, had to go to another supply house. I try to stick with viega tho.
    Plumber Raleigh,Plumber Cary,Plumber Apex ,Plumber Apex, Plumber Morrisville,Plumber Durham, ,Plumber Holly Springs,Plumber Chapel Hill,Sump Pump Raleigh
      I read Viega has the best warranty on their press fittings..
        the one supply house that did stock them here, switched over to viega.
        never had an issue with any brand. prices were similar at the supply house.
          Push fittings are for homeowners
            sean, the fittings we're referring to are propress crimp fittings. not the shark bite/ jon guess type you're thnking about.
              Sorry guys should have known you wouldnt use garbage like that.. first to admit never seen a propress looking forward to thou sorry for the confusion.
                I used close to 100 1" nibco press fittings , due to availability , on ajob last month. I had no problems or leaks. Nibco press seems to be a suitable substitute. I wouldn't be afraid to use them again.
