2 new boiler installs
  • 2 new boiler installs
ID:	635111Click image for larger version
ID:	635110Click image for larger version
ID:	635109Click image for larger version
ID:	635108Click image for larger version
ID:	635107Click image for larger version
ID:	635106After the wiring was cleaned up .It actually looks nice Click image for larger version
    Re: 2 new boiler installs
    nice looking work
    but i hope you did not wire it because that need some work like strapping it to the wall straight
      Everything with the pics got spread out. The supply /return runs to the fan coil units were pex.. Actually my first crimp ring transitions. To be honest I would have felt more comfortable using sharkbite couplings for the transitions..But time will tell I guess. The systems run great. I wired the outdoor sensors and they seem to work great too..The caleffi flow checks were a plus as they were a nice change fron the old cast iron monsters.
        Originally posted by HVAC HAWK View Post
        nice looking work
        No I did just the low voltage thermostat\ sensor wiring. The wiring was temporary and was re done by a master electrician..I will try and get some better pics after the clean up..Trust me , there is no way I would leave spaghetti dangling behind my work..Thanks for the kudos though..
          Nice work!
          Just 1 observation though...I notice some guys like to install their expansion tanks low, as you did in your install. Never really seen that done before around here.
            Beautiful work , BUT the schrader cap is tight on that self bleeder !
              Already taken care of ..Thanks
                Originally posted by Flux View Post
                Nice work!
                the tank looks like it has a base on it to sit on the floor ,i have done that a lot as long as you have a 30" clearance around it or if it is next to the boiler then the boiler then it all falls with in the 30" clearance
                i dont remember about the clearance when it is a wall hung boiler ,i put them up over 6ft
ID:	626528Yep these are floor standing tanks . Wasn't to worried about clearances etc. They are right there
                    Originally posted by OLD1 View Post
                    [ATTACH=CONFIG]16031[/ATTACH]Yep these are floor standing tanks . Wasn't to worried about clearances etc. They are right there
                    I've never seen an expansion tank like that installed on a hydronic heating system before. Neat set-up though.
                      Yeah , I thought it ws a little over kill too. But I figured what's wrong with a bit more expansion..
                        we have to have 30" clearance around any pressure vessel
                          Is that for commercial in our state? I never heard that one before.
                            Very clean work, I like the way you wipre and it looks like you sand your copper fittings and pipe after cleaning them. As for hte expansion tank, I just did a 35 gallon I think it was, it was a couple months ago, I love the free standing tanks when they are that big, imagine trying to put that thing on a wall!
                            Good job, excellent clean work.
                            Plumber Raleigh,Plumber Cary,Plumber Apex ,Plumber Apex, Plumber Morrisville,Plumber Durham, ,Plumber Holly Springs,Plumber Chapel Hill,Sump Pump Raleigh
                              Thaks a lot . I was expecting to install a much smaller well trol expansion tank but those monsaers were speced for the system. I didn't supply the boilers or pumps. The gc needed to make a couple bucks too. Yeah the copper really gleams. It 's all a timing thing and wiping while everything is still hot to the touch.I told the gc I would have liked to have done the job in propress..but elected to do it the ol' fashioned way
