Propress fitting question
  • Propress fitting question
    i asked this before but i cant find the old post
    after you PP a fitting does it look like this
    and another question is how often do you need to clean the jaws ,after pressing the fittings are getting stuck on one side of the jaw .so i clean it then another 7 presses it gets stuck again
    Re: Propress fitting question
    i've seen it happen before. it would be either the jaws are dirty or the fitting is slightly oversized causing sticky or bigger pinch.
    try cleaning the jaws with the supplied scotch brite pad and if need be try squirting some "pam" anti stick pot coating on the jaws.
      thanks about the Pam like i said i can do 5 or 6 press then it starts to stick and i do clean it with pad that comes with it
      what do you say about the way the copper is leaving a sharp point like the picture
        I'm not getting the "sharp point" like you are with mine. Maybe a very small dimple but not like yours. My jaws most always stick, I thought that was normal. I found that if I turn the tool slightly it breaks the jaws free.
          i will try turning it thanks
          but it still gets me about the sharp point
            My jaws for leave a point like that. Always thought it was normal. I just take a file and give it a quick pass to knock the point down
              i do the same thing
              just wanted to see how many other people this happens to
                Charlie,
                Can you post a picture of the jaw you are using. What I'm looking for is a close, clear picture of the tip of the jaw in the area where the sharp point of the fitting contacts the jaw. Are you using a standard or compact jaw, and is it only one size or is it all sizes?
                  it is on standard and on all in the set 1/2 - 2
                  i will post pictures next week
                    Originally posted by bmitch00 View Post
                    Charlie,
                    Mine happens on the compact jaws. 1/2" - 1"
                      Hawk,
                      Early on I had this happen on 3-2" tees. I cut them out and took them into Ferguson. They gave me another clamp and sent mine into Ridgid.
                      About a week later Ridgid sent me another clamp. Ferguson also replaced the tees.
                      Mine pinched so bad that it cut the rubber gasket.
                      All I was told that the calibration was off.
                        Originally posted by ArizonaPlumber View Post
                        Hawk,
                        thanks that may be my problem also and we also got the tool from Ferguson
                          Charlie, my propress has done this from day one, and that was years ago. It does it on all my jaws, 1/2-4"
                          As long as it doesn't thin it out to much or cut the gasket like someone else posted, I won't worry about it.
                          I did have an inspector years ago question me on it, so now if I think it is to much, I file it down.
                          Plumber Raleigh,Plumber Cary,Plumber Apex ,Plumber Apex, Plumber Morrisville,Plumber Durham, ,Plumber Holly Springs,Plumber Chapel Hill,Sump Pump Raleigh
                            i file it down but like you said if it thins it out to much and you also put a file on it that may not be good
                            i will post some pictures and they can see what is going on
                              Charlie,
                              here is 1 picture of a 1/2"
                              the rest are here http://public.fotki.com/hvachawk/my-...id-pro-press-/
                              when you go to the site click on a picture then on the top right next to the little flag you can make the picture bigger to see it closer
