10-24 threads
  • 10-24 threads
    I am a new be with this – is a pipe thread die a 10-24 – size 10 (3/16”) with 24 threads per inch? I did not see this on the site below – just says pipe thread. I have a 10-24 female knob I will need to insert 1/2" long stainless steel rod into.
    Thanks for your help on this,
    Re: 10-24 threads
    I don't know if this will answer your question or not but maybe this NPT chart will.
      Re: 10-24 threads
      10-24 is a bolt/screw size, for a #10 wire, sized bolt, considered the coarse thread, 10-32 is the fine thread
      it is a stand size for small bolts/ machine screws, #10, #8, #6, is very common, even #4 is not that uncommon,
      this chart is for drills and taps but there the SAE bolt and machine screw standard size.
      Bolt Depot - US Tap and Drill Bit Size Table
      general info on bolts and screws,
      http://www.fastenal.com/content/docu...renceGuide.pdf
        Re: 10-24 threads
        Both of these answers are very helpful. I couldn't find that info anywhere.
        I'm wanting to thread stainless steel rod 1/2" long to fit into a female 10-24 knob.
        Can this be done with the 300?
          Re: 10-24 threads
          the answer is absolutely not
          but the solution is very simple.
          buy some 10-24 ss screws and shear them off with an electricians wire crimper with the threaded screw shear built in. i use them all the time on small screws to cut to length. although the ss will be a harder screw to shear, it should not damage the cutter in that size. you might also be able to find short sections of ss all thread or better yet a ss set screw that's already 1/2'' long with a recessed allen socket.
          i believe 1/4'' rod is the smallest bolt die they make and i don't believe they make one for stainless that threads rod.
            Re: 10-24 threads
            i have a hunch we are all being played by poundcake
            all it takes is a little old reading of his post and you'll see what i mean.
            but in the mean time i will just leave my original post as is so others can see how it plays out.
            time will tell and so will his next post
              Re: 10-24 threads
              Thanks Rick. Just looking for this answer and I got it.
                Re: 10-24 threads
                If you think you need to do it under power, clamp the die in a vise and the rod in a 1/2 drill, dip the rod in the proper lubercant, and feed in to the die,
                  Re: 10-24 threads
                  Great Idea Thanks!
                    Re: 10-24 threads
                    you'll need to come up with some way to keep the rod feeding straight through the die else you will have a piece of scrap metal when you are done.
