12r die types
  • 12r die types
    I need new dies for my 12r 3/4 die head.
    I use it for black iron and galvanized.
    What is the difference in die types should I buy alloy or high speed ?
    Thanks
    Re: 12r die types
    Hs
    AllurePlumbing.com
    • leak detection
    • drain cleaning
    • utility locating
    • conductor fault locating
    • and other specialties.
      Re: 12r die types
      Thanks
      What is the difference ?
        Re: 12r die types
        Any suggestons ??
          Re: 12r die types
          Thank you for your inquiry.
          The difference between 12R Alloy and High Speed is in the application. Ifyou use your die head in tough demand applications, such as powered on a 300PDor a 700PD where the dies don’t have time to cool, you will get longer lifefrom the High Speed Dies. However, if you are using the die head for mostlyhand threading, or occasional threading, the Alloy Dies would be the preferredchoice.
            Re: 12r die types
            Originally posted by VinceD1955 View Post
            Any suggestons ??
            Don't buy generic, buy Ridgid.
              Re: 12r die types
              I like HS for everything carbon steel is for cutting wood MHO.
                Re: 12r die types
                The high speed have a more aggressive starting thread and are harder to start. Marvin
