Copper propress ridgid jaw identification needed
  • Copper propress ridgid jaw identification needed
    I just got this 1.25" fullsize propress jaw, it looks different than all my others, little 1/4 moons at the corners. All my other jaws are flat and 6 sided. Maybe this is an early jaw? Or somebody used it for something it was not made for? It is a ridgid made jaw.Any comments welcome Thanks!
    Seattle Drain Service
    Re: Copper propress ridgid jaw identification needed
    While I am thinking about it here is a picture of a copper 2" jaw with what looks like a ding in the jaw, I have never used it but may need to soon. Do you think the ding shown would effect the fitting?
      there is a code/ date stamp on the jaw casting.can't see it clear enough to see the date.
      the propress jaws are hand polished and final tested on a test jig at the factory in elyria, ohio
      the nick might just be a tattle tale mark to id it's from a ridgid jaw.
      at 1 time they required ridgid jaws for ridgid/ viega fittings. now everything is pretty much interchangeable.
        Hey Rick maybe I am seeing it wrong but it looks like the 2" jaw is out of alignment. Wouldnt that effect the press?????????????
        Over here Viega have the market as they are the only ones with >2" up to 4". We are getting absolutely reamed by Viega, no opposition
          the jaw is only out of alignment as it's not centered on a fitting. with only 2 pins holding the jaws together, it will move freely until you put it in a machine and center it around a fitting.
          are the viega jaws really viega, or ridgid jaws?
