pipe threading
  • pipe threading
    hello, collegues
    I'm prepearing short manual for plumbers aprentices - how to - pipe threading
    if any of you is willing to share basic tip on this matter is most welcome to do so.
    what is basic rules, precautions, when threading pipes with machine?
    Re: pipe threading
    how about this,
    http://www.ridgid.com/ASSETS/01D75C4...ader_Instr.pdf
    Edit:
    want to apologize as some how my mind got thinking manual threading, not machine threading, you may want to add it to you instruction list any way,
      Re: pipe threading
      Post a photo of the machine or model # and there should already be a detailed owners manual that exist.
      Is it a ridgid machine, rems, rothenberger/ collins?
      Rick.
        Re: pipe threading
        HAHA something wrong with this post. A your a pee an n ji neer wanting someone to tell them how to do something.
          Re: pipe threading
          Please clarify for which model or machine are you asking?? Secondly Is this a manual threading or machine threading?
            Re: pipe threading
            Originally posted by brikgreg View Post
            hello, collegues
            i'm prepearing short manual for plumbers aprentices - how to - pipe threading
            What is basic rules, precautions, when threading pipes with machine?
            Never ever,wear a necktie !
              Re: pipe threading
              Always use spell check when writing your manual, and have it proof read by someone else.
              You are more likely to not see your own mistakes than a fresh set of eyes.
              Using spell check on the forum never hurts either.
                Re: pipe threading
                Bob D. You forgot proper English--or whatever language he will use.
                  Re: pipe threading
                  I think NHMaster has a video of himself demonstrating threading technique.
                    Re: pipe threading
                    Actually, I don't understand why an apprentice needs a manual to learnt his most basic of pipe trades skills.
                    Isn't an apprentice by definition a person who works under the guidance for an expert in the field in order to
                    learn their trade?
                    How to use a rule, how to call out measurements, how to name a fitting, how to cut threads, these are all basic
                    skills necessary to cutting and threading pipe as we all know, and you learn them best not from a book but from
                    doing with someone coaching you.
                    So if a journeyman or master plumber is the best person to teach an apprentice, who should write a book about
                    the subject if one is needed?
                    You probably need a little of both worlds, the journeyman and the engineer. I think you need a co-author.
                      Re: pipe threading
                      I know there is a video of Rick threading faster than a machine some where on the forum, and He has a trophy to prove it,
                        Re: pipe threading
                        You can't beat on the job training.
                        David
                          Re: pipe threading
                          Yup.
                          I say, you listen and learn.
                          I do, you watch and learn some more.
                          You do, and I coach/correct where needed.
                          You're on your own, take it slow and build skill, speed comes later.
                          A few hundred times later you're a pro.
                            Re: pipe threading
                            Befor, I cudden even spel plummer, but I red this book and now I r won!!
                              Re: pipe threading
                              Injunears are like sand grains stuck in your underwear.
