Sweat fittings with Propress fitting question?
  • Sweat fittings with Propress fitting question?
    Can I use a FTG (or street) sweat fitting inside the socket of a propress fitting?
    Re: Sweat fittings with Propress fitting question?
    yes as long as you solder the copper socket first.
    and the length of the street fitting is long enough to bottom out in a press socket too.
    do a dry fit with a sharpie mark and look at it from the outside after you bottom it out.
