A job I did today
  • A job I did today
    I needed to change out an old tub valve. No shut off nearby, so I used the Ridgid freezer and then cut the galvanized. Then pro-pressed fastlock couplings with brass nipples and shutoffs. I would like to fully change out the galvanized, but it comes from an apartment below. Just a little more cleanup and strapping, and then the wall patch dude took over.
ID:	635912Click image for larger version
    Re: A job I did today
    Way to use all your tools/ toys in the ridgid arsenal.
    All you need is to clean up your soldering skills. Or swap to propress and forget about solder goobers.
    Didn't know that mega press was already stocked out here.
    Rick.
      Rick.
      I own the freezer, but I have to rent the propress. I just wait for days when I know I will really need it. I didn't even realize I left the pipe with those goobers. Thank God it's in the wall
      It's actually not mega press, but from cimberio valves that make those couplings. I had to buy the jaws specifically for them.
        Job well done..
        Monoprice Coupon Code
