max temp ratings of o-rings
  • max temp ratings of o-rings
    What is the max temp o-rings are rated for?
    ProPress connections are rated as follows:
    -Temperature: 0 degr. F - 250 degr. F
    -Pressure: 200 psi working pressure, 600 psi test pressure
    -Tubing: Types K, L and M (hard and annealed)
    If you have further questions about the temperature range, contact me (440-329-4454) or check out our NSF listing (www.nsf.org) which shows that we passed a stringent thermocycling test designed to show the ability of the sealing element to withstand temperature change.
