700 with no grease fitting
  • 700 with no grease fitting
    Just purchased a used 700 that has no grease fitting. What is the proper maintenance procedure to grease it? Thank you in advance.
    I would think as with most power tools one would have disassemble the case and pack grease in the gear boxes,
    (my guess is your talking about the power drive threader and not the drill)
      Pill the gear cover off. These machines are low speed threaders and do not require as much maintenance as say a 300. You might want to add a zerk fitting if you plan on regular lubrication.
        Thank you I will pull the cover and add grease if needed.
