rigid sump
  • rigid sump
    my new rigid pump with float switch only stays on for 6 or 7 seconds. Any way to increase the cycle time??
    Re: rigid sump
    What does your owners manual say? Have a look HERE
    You will never expand your mind, if you do not challenge your beliefs.
    By the reading of this post, you acknowledge and agree that the poster shall not be responsible or liable, directly or indirectly, for any damage or loss caused or alleged to be caused by or in connection with use of or reliance on any content contained herein.
      Re: rigid sump
      nothing in owners manual re this problem.
        Re: rigid sump
        My Guess Would Be That Your Sump Pit Is Too Small Or Too Shallow. Your Pump Puts Out More Water In 5-6 Seconds Than The Sump Can Hold. You Might Try Going Deeper Or With A Bigger Diameter, Both Sound Like More Shovel Work.
        Jake
          Re: rigid sump
          nah, there's still water in the sump when the pumps shuts off. Would be nice if it would just pump a few seconds longer. I'll probably take it back (lifetime guarantee) and try another one. Thanks.
