Chemical root killers?
  • Chemical root killers?
    What is your opinions of chemical root killers, what is there effectiveness, Basically the ones that are copper sulfate based, (copper sulfate pentahydrate). or street names (Blue Vitrol, Bluestone, Cupric Sulfate).
    basic suggested use or instructions,
    http://www.aquaweed.com/copper.htm
    Sewer Treatment for Root and Fungus Control
    PHELPS DODGE REFINING CORPORATION TRIANGLE BRAND COPPER SULFATE PENTAHYDRATE
    is most effective in keeping sewer lines free of roots.
    A. FOR PARTIAL STOPPAGE: Add 1/2 pound of copper sulfate pentahydrate to
    sewer or drain and flush toward blockage with 5 gallons of water. Repeat at 6
    month intervals to prevent growth of new roots.
    B. FOR COMPLETE STOPPAGE: Physically remove the root blockage and repeat as
    above.
    C. FOR HOUSEHOLD SEWERS: Use 2 - 6 lbs. copper sulfate small crystals twice
    yearly in spring and early fall. Apply in toilet bowl near sewer line. Flush
    each 1/2 lb. portion at a time. Or, remove the clean-out plug and pour entire
    quantity directly into sewer line and flush with water. NOTE: DO NOT APPLY IN
    SINK OR TUB DRAINS.
    D. FOR COMMERCIAL, INSTITUTIONAL AND MUNICIPAL USE:
    SEWERS: Use 2 lbs. of copper sulfate small crystals each 6 to 12 months,
    applied to each junction or terminal manhole.
    STORM DRAINS: Use 2 lbs. of copper sulfate small crystals per drain per year.
    Apply during period of light flow. In dry weather induce a flow with hose. If
    storm drains become almost plugged, repeat treatment 3 or 4 times at two
    week intervals. SEWER PUMPS AND FORCE MAINS: Place 2 lbs. of copper
    sulfate small crystals in a cloth bag at the storage wall inlet. Repeat as needed
    I realize this is not approved in all locations, but where it is, what is the professionals opinions?
    Re: Chemical root killers?
    it does work, but there are limitations
    90% of the roots come in from the top of the line. the waste flow is at the bottom of the line. until the roots grow into the flowline, the chemical is useless. if you can apply the lethal dose 2-3 weeks prior to a stoppage, you'll do good. the issue is when is that 2-3 week period
    the best bet is to apply heavy in early spring and fall. then normal every month. the stuff is cheap, about $8. for 2#. this should last about 1/2 year of treatments.
    the better way is to use a chemical, such as "root-x" once a year.this is a foaming agent with root killer. so instead of waiting for the roots to get to the chemical, the chemical foams up and gets to the roots at the top of the pipe. the issue is cost. a 2# treatment will cover approx. 50' of 4'' pipe. it cost approx. $35. chances are you will need 4# to cover the pipe thoroughly
    with either product, you need to stop using water for 4-6 hours.
    root-x is best applied through a sewer cleanout. in a toilet you better know what you're doing, or you will have a living breathing monster remember it foams on contact with water.
      We sell/install about 24 lbs of Rootx a month. Allows us to offer a 1 year guarantee on a mainline cleaning, even with agressive roots.
      It requires a pesticide licence to use in california, though. (a pain to get)
      Worth it for customers that don't have the scratch to fix the real problem (THE FAILED PIPE!)
      I love the stuff, and everything Rick said is dead on, especially about not running water foer a while after the application.
      "Never try to teach a pig to sing; it wastes your time and annoys the pig"
        Yea, what Threefingered said, and as usual what Rick said. But here in Mich, we have alot of combination sewers, so these customers have to also make sure water is not flowing through storm trap, or that its not raining or wet weather, cuz the rooto will obviously flush right through.
          the living breathing monster comment made me laugh. The first time I used root-x was through a toilet in a customers home. I flushed for all that toilet was worth and just didn't quite make it.
          Then I read the directions, something about not applying more than 2lbs through a toilet, I had dumped a bucket with 4 pounds in it into the toilet.
          In retrospect it's pretty funny.
            I've never heard of Root-X. Thanks. Rick, your knowledge base seems to be endless. So... <---- What does that emoticon mean?
            Thanks in advance.
              Root-X all the way. Although sometimes I think it works a little too good.
                I put too much root x in a front yard cleanout and had a mini volcano. Had to buy some sod as that lawn was not going to grow back for a long time.
