garden hose with sump pump
  • garden hose with sump pump
    I would like to connect a garden hose to my sump pump on a temporary basis. Since this is smaller than the 1 1/2" pipe normally used, is there any risk of damaging the sump pump? I need to do this for a couple of months.
    I have the fittings all ready to do this, but I thought it would be prudent to ask here first.
    Dave
    Re: garden hose with sump pump
    depending on the size of the pump, gpm. the hose will not allow as much gpm and will create a head loss.
    as long as you don't expect it to keep up with the original installation in gpm or total head, it will pump. try to use a 3/4'' id hose.
      Can you run temporary 1-1/2" pvc line? If not, depending on the pump, you could add excessive wear if you chock the line down that much.
      the dog
        Buy some of the flexible 1-1/2" hose sold for pool pumps. Then you don't have to worry about it.
        Buckeyetech
          Due to the good advice I recieved here I went with plan B. I used 1 1/4" flexible sump pump discharge hose and everything is fine and I don't have to worry about some of the issues mentioned here.
          Thanks again.
          Dave
