trash pump recommendations
  • trash pump recommendations
    a buddy of mine jumped the shark on that bad weather in the NE. he is looking for a 2 or 3 inch gas powered trash pump for the next time it rains like this.
    any suggestions?
    thanks
    steve
    Re: trash pump recommendations
    i have both a 2'' and 3'' trash pump and a 3'' diaphram pump.
    these will pump tons of water and the diaphram pump can pump dry without damage.
    honda motors are a good call. also very important are the hoses. use pvc hoses that don't lay flat. you need a hose that can work on the suction side and a hose rated for pressure. i use the pvc hoses for both. they connect with cam and grove fittings. 2 snaps and you;re good to go.
    make sure to remove the gas when finished for the season and clean out the debris from the volute.
    my 3'' trash pump will do 21,000gph.
      A little hint about something to put into gasoline for small engines you don't use all year long. This stuff really does help. Be sure to measure carefully.
      http://www.goldeagle.com/sta-bil/index.htm
        Rick, is there any tool you DON'T have??
          there are some, but i don't know what they are
          ps. just got the 3650 last week.
