Weird Noise .....
    Re: Weird Noise .....
    that ballcock has a relief valve built in to allow for thermal expansion. it's not designed to replace a properly functioning pressure regulator and pressure relief valve.
    you had success with the pressure regulator. why not get the whole association to check their pressure and replace the worn out regulators?
      How old is your development? Maybe you (the HOA) can collectively petition to have the developer pay for this. If the PRVs that he installed are sub-standard you might have a case.
      Replacing your pressure regulator valve was the correct fix.
