Your top 5 tools
  • #31
    Re: Your top 5 tools
    Can't any of you jackasses spell STABILA correctly? It's not that difficult!
    • #32
      what crawl up you but and died?
      9/11/01, never forget.
      • #33
        on the 5 top tools,
        so much depends on the day, and what the job is.
        a slab of concrete,
        or framing a building,
        helping run wire, or electrical.
        hanging or finishing drywall.
        cabinet making in the wood shop,
        cleaning out a drain,
        over hauling a motor,
        rebuilding a transmission
        welding up some machine or building something,
        turning and milling out parts on the metal lathe and milling on the Bridgeport,
        running a backhoe or tractor,
        fixing tires,
        pulling and fixing a well,
        preparing or planting grain, or feed
        harvesting grain or feed,
        Doctoring or branding cattle,
        Fixing fences,
        milking goats,
        helping hard birthing baby critters,
        butchering and cutting meat,
        but my number one tool is my Gerber multi tool, that I will use on most any type of job where ever or what ever,
        gloves.
        next I would probably say a claw hammer,
        two sets of open box end wrenches, (at least one set and an adjustable open end, crescent type).
        good screwdrivers set,
        these may not be always be the most used, but with out them I would have a very hard time do most any thing else, a least after a short time when something would need to be maintained.
        • #34
          #1 HELPER (wife, son, daughter)
          #2 1 1/4" General sectional snake Powered with 1/2" Ridged drill
          #3 Gen-eye camera with locater
          #4 Tom Tom GPS unit
          #5 anti bacterial no water needed hand wash
          AND DUCT TAPE
          • #35
            [quote=Gene Bickford;76427
            [/quote]
            gene, did you make an adapter to run this cable in your drill?
            what speed do you run at?
            i have the general #88 3/4h.p. and there is no reason why a drill motor shouldn't work in a pinch or for lack of space.
            have you had good luck with this combination?
            thanks,
            • #36
              Crecent wrench/hammer
              6 way screwdriver/chisel
              12" flat screw driver/pry bar
              6 ft clear hose for sucking out toilet bowl overfilled due to stoppage
              pepto-bismal for these strange stomach bugs.
              • #37
                Stop using the 6 ft clear hose and you wont need the pepto-bismal for those strange stomach bugs
                • #38
                  Now that was a good one!
                  • #39
                    thanks,
                    I've had awsome luck with this combo. I need to get a new camera. when I do I'll try to post a pic and more info.
                    • #40
                      crack, i knew you were sharper than your picture
                      i've owned these bits for years before lenox bought them.
                      i get a kick at the trade show to demo the 4 5/8'' bit with 1 hand on the drill through a 2x6
                      I'm pretty sure I invented those bits 20 years ago but no one believes me.
                      • #41
                        Okay just to show how things change. Today my 5-favorite (most used)tools are:
                        1. Nikon CoolPix 8800
                        2. Fujitsu stylistic Tablet (in an OtterBox)
                        3. Delmhorst MoistureCheck
                        4. Trimble HD150 Handheld Distance Lased Meter
                        5. Bacarach Fyrite Pro 125 Combustion Analyzer
                        • #42
                          I'm jealous
                          • #43
                            I agree, I'm a poor speller. Sorry it offended you.
                            the dog
                            • #44
                              gene, thanks for the suggestion
                              i took my 1.25'' general cable and made an adapter to fit my 1/2'' hole hawg. i have a complex that has 2 problem sewers in the alley. the street level one is 24' and the sub terannian garage one is 15'. what a pleasure it was to use the drill in slow speed @ 300rpm to clean these 2 lines. i now can do it in half the time since i don't need to hump the beast up and down the building. 30' of cable in 1 hand and the drill with 50' of cord in the other
                              thanks for the great idea
                              • #45
                                Ridgid 300
                                Portaband Saw
                                24" Al Ridgid Pipe wrenches
                                Greenlee Pipe vise Tri Stand
                                My fold up pipe stand one of the 3 piping tools I own thats not a Ridgid sorry.
