pvc trap adapter
  • pvc trap adapter
    i bought a 1/2 to 1/2" pvc trap adapter
    in reality, i need a 1/2 to 1/4" because my wall pipe is 1/4". can i just get the threaded nut in a 1/4" size, and use the adapter i have now? or do i have to buy a whole new piece from 1/2 to 1/4?
    reason is, because i would like to cement it up now and buy the threaded sealing nut tomorrow.
    thanks,
    pete
    Re: pvc trap adapter
    I think what you are saying is you already have a 1 1/4 trap adapter stubbing out of the wall.If so you'll need to connect from wall to tailpiece with 1 1/4 tubular trap.Can you redo to where there is only 1 1/2 pvc pipe coming out of the wall?
      you can use the 1-1/2 x 1-1/2 trap adp you have now and just get a 1-1/2 x1-1/4 reducing washer for the nut
        Re read twice, now I see what you mean,never have been a good listener
          thanks guys,
          i ended up buying a 1.5 to 1.25" trap adapter, and another 90, and subsequently swapped the new pair out for the old. luckily i didn't weld/cement the last piece in, so i went that route.
          best,
          pete
