Jet swet under live pressure
  • Jet swet under live pressure
    Has anyone used a jet sweat under live pressure(55 psi)? I am going to try this in a couple days and was planning on opening all the fixtures to relieve the pressure. I need to heat the previous valve off so propress isn't an option. This is a military building and PW needs 2 week notice before they turn off the water. Any thoughts, advice?
    Re: Jet swet under live pressure
    I wouldn't advise it.
    the dog
      don't do it
      they claim that they are rated for 60 psi.
      what size pipe is it. what will happen if it doesn't hold? what will get flooded?
      too many what ifs
      do like me freeze the pipe
      looks like my panama trip might get diverted to virginia beach
      they make a jet Sweet tool with a bypass hole in it to allow for pressure to drain. but not designed to take full flow of an open line.
      maybe you would like to buy 1 of my 4 freezing kits
      2- complete co2 kits to 4'' and a ridgid super freeze 2000 and 2500.
      josh don't i have enough ridgid points to get a round trip flight to go help out our country
      you could join us and then we can golf
        What size is the inlet and pipe you are working on. How many fixtures can you open to relieve pressure.
        THE GLASS IS ALWAYS HALF FULL
          At 55psi I'd think the plug would shoot out like a bullet. What do you have for pressure with all other valves open? Even then I'd think it would be on the dangerous side. I've never used one but it seems kinda risky to use on the fly.
          Could you use a freeze plug instead?
            looks like Rick beat me.
              Maybe I smoked way to much wacky in my freshman year,I swear it gives me a totally different perspective when I read your posts with her picture as your avitar,it's absolutely hillarious (in my own twisted mind)
              Can you keep it for a little while,makes me think of "62's" yank.
              Saw this on a bumper sticker a few weeks ago "Guns kill people like spoons make Rosie O'Donnell fat" .Been sticking with me,maybe make it my catch phrase in a little while.
                How about a mechanical couplinng with a full port valve , as far as heating the old valve off , I don't see it happening unless you freeze it like Rick suggested . Joe
                  don't do it
                  too many what ifs
                  Rick,
                  Come on, you have yourself admitted that the freeze systems are limited at best. Now you're tring to sell one?
                  the dog
                    just 4 u dirty hands. Till morning.
                      Originally posted by plumbdog10 View Post
                      Rick,
                      dog, they work when you know their limitations. meaning you can't freeze moving water. if the line is dead ended/ no running water, it will freeze. the time it takes to freeze depends on the size of the pipe, the ambient temperature, the type of pipe, and the type of machine.
                      liquid co2 is -109f.
                      ridgid superfreeze is not as cold, but it only requires electricity to run. no heavy co2 bottles to run out.
                      the superfreeze 2500 will do 2.5'' copper.
                      the liquid co2, i have bags for up to 4'' pipe.
                      who said i was trying to sell 1
                      i will sell my superfreeze 2000 and 1 set of co2
                        This is just 3/4" pipe. I can turn on 1 urinal, 5 toilets, 2 showers and 2 sinks. It's a concrete Bathroom w/ floor drains so water isn't a big deal. From the responses, I'm not going to do it. Don't have access to a freeze kit.
                          What size is the feed line for the building? I have seen urinal stop changed out with water on. You might get enough pressure drop opening up all these other fixtures. I would remove drop in kit to urinal so it would full flow water out. And same on toilets, run right off toilet stop, flex pipe to floor drain, so you would get full flow of water out.If that's your only option. If You could not un sweat stop maybe you could cut pipe and use compression stop? if it dose not go as your 1st option. Freddy
                            I believe a fairly new jet sweat would hold at least for a while against 55 psi.
                            I have my doubts whether you will be able to push it up through the valve against full pressure.
                            I say "go for it" but wear a raincoat
                              I tried it today and it didn't even come close to working. With all the fixtures open the pressure dropped to 42 psi. I took the handle off and connected my drill to open the valve faster. 42 psi is a lot of pressure. I couldn't even get the jet swet in 1/2". I closed it up and told all the occupants that I was shutting down the water in 1 hour. Turned off the water and changed out the valve. No drama, went like clockwork.
