Moen mixing valve
  • Moen mixing valve
    I have a Moen mixing valve in my tub/shower and I cannot get any cold water out of it. Does this mean a new cartridge is in order or just a cleaning? Or maybe something else? To give a little back ground, it acted up a couple of weeks ago, but I turned it off/on a couple of times and it was fine. That doesn't work this time. Any advice is appreciated.
    Jim
    Re: Moen mixing valve
    Jim
    I usually clean and flush out the rough valve body with full house pressure before installing a new cartridge,be carefull not to gouge the inside while your trying to remove the mineral deposits.
      Changing the Moen cartridge is the easiest faucet repair there is. More than 15 mins you are doing something wrong. The hardest part is getting the old 1 out.
        Don't forget to add a light coat of plumber's grease to everything rubber. Rough mineral deposit can be softened by soaking some paper towels in vinager then shoving the towels in the valve body for half a day. The deposit will wipe right off then. Then flush the valve body w/ water.
        Ben
          This will help to get the old cartridge out, I use it for 1225 & 1222 cartridges.
          Crappy picture but you get the point.
            Thanks for the quick replys. Sounds like a cartridge change is in order. I guessed that would be the answer, but wanted to ask in case someone had run into something that I hadn't thought of. "Crack", I agree, the toughest part is getting the old one out--just changed one in the lav faucet a month ago. Thanks again, Jim
              Check with the plumbing guys at HD, they usually have a stash of mixers in a drawer in the new kitchens section that they give out for free to warranty claims. Just bring your old valve with you. I think Moen qualifies for this
                Well since no one else bothered to ask, Do you turn the handle or pull the handle to turn the water on ? it makes a difference.
                If you turn the handle counter clockwise to turn on the water , a cartridge is all you will need.
                If you pull the handle out to turn on the water , you need the balancing spool.
                  PIPES: Thanks for the response/question. I turn the handle. I should have posted the model number and made it easier to respond--my boo-boo. As an update, I called Moen first thing this morning and a new cartridge will be here tomorrow. (Had to pay for the speedy shipping, but that was cheaper than the gas to go to the nearest HD to see if they had one as WBrooks suggested--80 miles round trip) Same distance to the nearest plumbing shop. Thanks again, everyone.
                    very good obsevation pipes
                    i would have guessed it was a balancing spool as a normal 1200 0r 1225 cartridge typically doesn't plug up. i would think that when he removes the cart. he will find some debris in the port. make sure to flush out the valve before installing the new cart.
                    if you do have a balancing spool inside the cart. it can easily plug or freeze up. this is usually by construction debris, hard water, and lack of use.
                    the side spools are also another issue, but mine are now 15 years old and still working fine and have not replaced anything yet.
                      UPDATE: The new cartridge came today and is installed. Plumberscrack, I failed the test--it took me an hour. I couldn't get the old one out using the method they described, but a little ingenuity and a lot of cussing finally overcame!! The interesting thing was what caused the cold water stoppage. It wasn't mineral buildup, construction materials, etc. The rubber flange on the side of the cartridge had come off and somehow (????) got wedged in the incoming pipe. That took a good part of the hour trying to get that out of the pipe. Final note: Happy showering tonight!!
                        Yea seen that a few times; kind of a fluke thing that some Moen cart. do.
                        It took you an hour because you read and followed their instructions.
                        I usually keep a roll of quarters nearby for the cussing jar.
                          the plastic magnum cartridges are usually very easy to pull. the brass carts. can be a real pain. the 2 pullers are useless until you use a vice grip to pull the center stem. then a puller with a ball detent or a proper easy out is all it takes.
                          i always use a copper brush/ 3/4'' to clean the valve then flush out the body before installing the new cart.
                          pipestone kid, keep this in mind in another 10 years
                            Plumber Rick, if I need another in ten years, I will have you and Mrs Seatdown come over and change it . Then we will sit on the pontoon and catch some nice fish and drink some cold ones.
                            Jim
                              Jim
                              you got a deal. just swap out the cold ones for some root beers and i'll book it. mrs. seat down is waiting for an anniversary trip. she tore/ detached her retina and had an interesting procedure done to help reattach it. can't fly till the gas bubble dissolves.
                              wait till i tell here where we are going
                              correction, she has a tendency to log on at work and check up on me
                              now if only i can collect on the steak and brownies from other members.
                              thanks jim.
