Fine thread Hose Bibb???
  • Fine thread Hose Bibb???
    I had a Hose bibb that was dripping pretty good. Went and picked up a couple 3/4" hose bibbs to replace it and after finally being able to get it off, I found out that I had fine thread and looks nothing like the one I bought. I assume that when my house was built 2 years ago that they sodered my faucet on and even filled in with mortar that I will never be able to remove it without extra costs to replace it with a course threaded one. Is this normal?? Where do I buy these things? What will I need to do if I damaged the thread taking it off?
    Re: Fine thread Hose Bibb???
    pls post a picture!!
    Robert
      Is this an outside hosebib or maybe a laundry bib?
      Brent
        Outside. hold on a sec for a pic.
          sounds like the thread from a factory installed vacuum breaker. the vacuum breaker was removed and this left you a very fine larger than normal thread.
          a picture will confirm this.
            I'm wondering if it is the bibb or is it the VB he is replacing?
              deja vu
              or 2 minds that think alike
                But does not a vacuum-breaker have hose threads, which have less threads per inch than a pipe thread?
                the dog
                  Im sorry guys. I'm having trouble posting the pic.
                    OK. let me know if you need a better pic.
                      dog,
                      Some of the manufacturers have quit using the hose thread size VB to comply with the non-removable part of the code. When the plumber neglects to break-off the screw the VB is no longer non-removable.
                        not sure of your question.
                        a factory installed v.b built into the hose bibb can be removed with some skill and be reinstalled with even more skill. the hose bibb is useless for connecting a hose to if the v.b. is removed.
                        i learned the hard way during years of new construction that soldered on hose bibbs and factory installed v.b are not the way to save money. i had many of v.b. to replace and service. much faster than shutting and draining the system.
                        dog where have you been hiding?
                        we got an election to run and a golf game to play
                          Bingo that is the vaccum breaker not the hose bibb. If you can replace it , it will have to be from the same manufacturer.
                            that's a vacum breaker,not hose bibb.Does the faucet leak when you have it turned off?was the set screw broken off in the vacuum breaker?sounds like it was,the hose bibb should be completly removed and new one istalled
                            Robert
                              Did I mess up by taking it off with my channel locks? How do I fix this?
