Flux
  • Flux
    Which is one do you pefer?
    Nokorode paste flux or Utility flux?
    Re: Flux
    actually i prefer everflux. it's from the u.k.
    seems to work the best out here.
    i did pick up a sample of another flux and will try it out.
    nokorode used to be the best.
    we are talking about water soluble flux, correct
      Re: Flux
      I love Everflux, I was in another state for 6 months doing plumbing and didn't have everflux, had some other crap, dissapointment, I missed my everflux
      Robert
        Re: Flux
        I use no-korode for soft soldering , c-flux for braising silver on existing copper
          Re: Flux
          Tried Nokorode for awhile, didn't like it and I forget why.
          The only thing that seems to make a major difference is the solder...95-5 is my ONLY solder...Silvabrite is my choice.
          I don't dare keep 50-50 around...not even on DWV...runs too fluid so you tend to have to baby-sit the torch on how hot the copper gets so it doesn't leave crevices from flowing out of the top of the fitting, also it smears too much.
            Re: Flux
            DB, you are just out of practice. You probably learned to solder with 50/50 like I did.
            Utility is my normal flux but for dirty old copper I like Laco
              Re: Flux
              I'd used it alot when I did commercial dwv.
              There's no way to avoid the way it spreads out from the hub...95/5 doesn't...just gives you a nice clean joint with a manageable bead at the bottom and spreads thicker because of it's higher melting point.
              Guess it's all a matter of preference.
                Re: Flux
                Your lucky,Were not allowed to use any flux that's not water soluable.
                  Re: Flux
                  add, no lead solder. no 50-50. although i have some stashed for that just in case senario.
                  scratch that
                  no flux, no solder, no torch
                  propress 2 jobs with it today.
