Pex to Polybutylene
  • Pex to Polybutylene
    why 2 different rings? I use the black rings on booth and have not had a problem.
    Re: Pex to Polybutylene
    Call the manufactor, maybe they can shed some light on the subject.
      and then when they do, please post back and let us know
      Robert
        Funny this would come up...Just Today I had a Pex coupling burst in my very own basement. Luckily I happened to be down there and shut off the water as I soon as I could. Upon closer inspection, i noticed the previous plumber ( or more likely homeowner) used a poly b x pex adapter, with one one ring of each kind. I'm glad the rest of my house is copper.
        West Trail Mechanical Ltd
        www.westtrailmechanical.ca
          are you able to identify the ring that burst, the manufacturer? i am very curious if it was wirsbo or rehau or some other brand
          Robert
            There may be a difference in the metallurgy of the copper alloy? I don't know of any one up here using the insert fittings and crimp rings with Uponor or Rehau. I only see them on the crap pipe like Zurn,Bow-pex etc...
            You will never expand your mind, if you do not challenge your beliefs.
            By the reading of this post, you acknowledge and agree that the poster shall not be responsible or liable, directly or indirectly, for any damage or loss caused or alleged to be caused by or in connection with use of or reliance on any content contained herein.
