roof vents
  • roof vents
    hi all, i have 3 sewer vents extending through my roof, two 2 inch and a 3 incher.as i am re roofing my house i was thinking i could tie the 2 smaller ones into the bigger one and have less leak prone areas to worry about as we get lots of rain to deal with here.
    thanks
    Re: roof vents
    Sounds good to me
    YourHomeContractor.com - The Trusted Online Community For Homeowners and Contractors.
    Plumbing Reviews
      Re: roof vents
      Simply too much work.
      Proud To Be Union!!
        Re: roof vents
        Agree with Aaron, it's probably easier to put three new flashings on than tie those vents together. A properly installed flashing should last as long as the shingles...unless its lead and the squirrels start gnawing on it.
          Re: roof vents
          If all the vent are tied into together then you'll put a plumber at a real disadvatage if he ever has to snake your line through the vent. Sometimes that's the only way. He'll make sure he get "compensated" for the difficulty.
            Re: roof vents
            I just did one that they put a "T" in and it cost em $500 by the time I got done. If your not a plumber dont screw with the vents!!!!!!
              Re: roof vents
              It's not like you have 8 vents going through the roof, you only have 2- 2" and 1 - 3" I would just leave then and make sure your roofer does his job properly.
              The other thing, if you have a 4" sewer, you need a certain amout of air in your sewer for it to drain properly and keep the trap seals, when you shrink the vent area, you shrink the sewer area and can cause trap seals to siphone among other problems. Here is mathmaticaly why you cannot do it:
              On a 4" sewer, you need 12.56 area, so lets assume with 1-3", and 2-2" you have a total of 13.34 area, now, let's say you need 12.56, if you lose one of those 2" vents, (1-3" and 1-2") it cuts you down to 10.20 area, if your main is 4", you need 12.56, you are 2.36 short.
              If you have a 3" sewer, you need 7.06 area. and you can tie both those 2" vents into 3", but then you run into the snaking problems etc, if you don't have a c/o.
              Wordy, but if you read it a few times and do the math, you will get it.
              Robert
                Re: roof vents
                grasshopper, with answers like that, you'll be moving up to master grasshopper real soon
                true, you need the same amount of cross sectional area as the sewer that leaves the building. so robert, although a little confusing in his explanation, he is correct
                now as a practical explanation goes. as others here have mentioned, you can never have enough vents, especially if you need to snake from a roof vent. i would extend them all through the roof. you've already got plenty of vents tied together with only 3 vents now.
                all get a thumbs up
                  Re: roof vents
                  all get a thumbs up
                  Thanks Daddy, I told you I have a hard time putting things into words My brain moves faster then I can write or type.
                  Robert
                    Re: roof vents
                    ok...lost here on the vent thing...we simply require a 3" main to be 3" all the way through the roof..a 4" the same and so on.
                    To me with a 4" requiring 12.56 area...a 4" would be the area of a 4" (4 x 4 x .7854)...why not just say 4"?
                      Re: roof vents
                      Well here I go not being a plumber but questioning two excellent plumbers opinions.
                      I get that Area = π r² but practical experience tells me you need far less cross sectional area to let enough air in for a given cross section of fluid output. Consider the lowly gas can, it has a relative pin hole size air input compared to the gas output and yet it does not lack for air flow to allow full gasoline flow.
                      I may be wrong but please tell me why.
                      Not questioning the logic behind more vents for snaking that makes perfect sense
                        Re: roof vents
                        It's about having equal air pressure on both sides of a P-trap to prevent siphonage.
                        Brent
                          Re: roof vents
                          dude, thats what I mean't, just in a round about way
                          Robert
                            Re: roof vents
                            Robert, the funny thing is I read your post and said you must have quoted the code book
                            Joey
                            I love my plumber
                            "My Hero"
                            Welcome, Phoebe Jacqueline!
                              Re: roof vents
                              I am sure the system will operate on less area, but according to the UPC, the minimum standards were listed, I am not an engineer, it may work on less, according to the gas can example. I quoted the minimums, which I am required to adhear to
                              soon you will not be waxing my cars you will be telling others what to wax master grasshopper
                              as per the upc code book. the cross sectional area of the building sewer has to have an equal or more cross sec. for the roof vents.
                              there are times when the sewers have a positive and a negative pressure. it all equals out this way. now with jetters, the more venting, the better.
