PE Fittings
  • PE Fittings
    I'm being told that that they now make "push-on" fittings for PE gas pipe that are UPC approved. Does anyone have experience with these?
    the dog
    Re: PE Fittings
    the same as sharkbite, scarry the amount of play in the fitting
    how is it that so many answers are in the instructions
      Re: PE Fittings
      I had a plumbing inspector telling me about them a few months back, forget the name but he and I jokingly agreed best to let more brave souls be test pilots and sit back in wait for potential lawsuits.
      The whole PEX crimp thing is starting to buzz with the "L" word of late.
        Re: PE Fittings
        dog, if it's what i'm thinking, they've been around for many years. i've used just the couplings for up to 1.5''. the gas co. has used them for years to keep from fusing pipes in emergencies.
        try central plastics. they are mechanical fittings/couplings.
        the fittings are spendy and are almost identical to a sharkbite fitting in principal. you need to chamfer the outer edge and mark the insertion depth.
        they are not removable or reusable. unless you bet me and i take the salesman $100.00 i was nice and only asked him for lunch
        please note they are hdpe. high density poly ethelyn
          Re: PE Fittings
          I found out today that there is a company using PE Pipe and Fittings to run potable water in homes The guy there was running chiller and gas lines in el camino college. they ran all fiberglass water lines etc, he was there purchasing some pe fittings for the gas line and this is how the conversation started. He spoke highly about the quality of the PE Pipe and fittings and how great it is when it is used on water systems.
          Anyone heard about this? PE Pipe and fittings for water systems. Is it legal? I cannot recall if it is a material listed under approved material for a potable water system. Is it approved with a verience??
          Robert
            Re: PE Fittings
            What have you heard?
              Re: PE Fittings
              robert, cities are using this as a sliplining material for water mains.
              a few years back i saw them using 24''-36'' hdpe pipe to slipline the potable water main. this is sort of the pipe bursting principal without the burting.
              the material is so slick and clean that even though they lost a few inches of diameter, (wall thickness plus clearance) it still provided more than enough volume due to a better coefficient of friction.
              i still believe that the original question posed by dog was based on a gas hdpe fitting
                Re: PE Fittings
                ZurnĀ® Class Action Informational Website
