Job Related Question With Picture
  • #31
    Re: Job Related Question With Picture
    Originally posted by plumberscrack View Post
    Is this a misprint or are you showing off?
    no misprint. remember it was production. i would shut off the water to the building. while it was draining i would distribute the proper stops and estucions to the units. i had already pre prepped the stops with dope/ wax.
    as long as the counter tops were not installed, no problem. the copper bullets were cut, an estucion was installed and the stop was tightened in a matter of seconds. with the proper wrench, it was no problem.
    then i still had to turn on the water and walk the units, to make sure the painters and drywallers didn't leave a valve turned on looking for water.
    ps. as jojo just mentioned, i was 20 years younger
    now i can probably do 500. wanna race
    you do wear the skin on the knuckles pretty quick.
    • #32
      Thats at a rate of one every 50 seconds, not including lunch.
      I could do that in my sleep with one arm tied behind my back.
      • #33
        HAHA Duck, the race is on
        This was from condos/apartments, with each haqving 3 per bathroom with a toilet and sink, 2 for the laundry and the kitchen had 2 plus an ice maker or bar sink. So he didn't have far to go.
        He doesn't have to work this hard any more. (As I type this Rick is on his way to an emergency-on a Sunday)
        I love my plumber
        "My Hero"
        Welcome, Phoebe Jacqueline!
        • #34
          I remember hearing a legend about the job where Rick and two other guys did a 55-story building from canning the slab to setting finish in less than one year.
          or may I do not
          • #35
            or may I do not
            I coulda done it alone.
            In six months.
            With my eyes closed, juggling banana's on a unicycle.
            With offsets in the stack every other floor...of course.
            • #36
              or may I do not
              Thats quite an accomplishment there Rick
              I think I got the best commercial plumbers in the business and they would never be able to do that. You should feel proud
              • #37
                I now "BOW DOWN" to duckbutter. He is the king.
                My guys are screwing me
                Regards,
                • #38
                  I beat you all to it! I mentioned it as he was typing! LOL
                  Poor guy is out working while he is being made fun of
                  I love my plumber
                  "My Hero"
                  • #39
                    Biscuit, I'd offer to come out there n' show 'em how it's done, but I'm...er...busy...plus wouldn't wanna demoralize them too much.
                    I'm a good guy, yeah, thats it.
                    • #40
                      Hell, if you can do all that, I will put you to work tomorrow
                      However, since you said it, if you dont perform, I would be forced to let you go by tomorrow afternoon
                      Its all business!
                      Have a great weekend everyone, I am going home to see my wife for a few hours and relax a bit. Dont get to do that often enough these days.
                      Regards,
                      • #41
                        I have a couple types of pullers on my van, a need to have tool. I kinda do a pre test, I try to pull the nut a ferrell off with a pair of channel locks before I use the puller, if it fails, then I ise the puller, if the pipe stretches, then you have no choice but to use a MIP.
                        As far as for very slow leaks, I check and re-check the connection when I use a compression set up, I also clean the copper before I slide on the new nut and ferrell.
                        I never cut my copper close to the escusion, I leave room for the either me, or the next guy who has to replace it someday.
                        I piece stops suck to high heaven, worst thing around, especially the ones with the little white round knob nasty, nasty nasty stuff.
                        Remember, quality, not quantity. I would rather loose the job then install junk and be called on it later.
                        Robert
                        • #42
                          Dats what I'm talkin' bout.
                          • #43
                            not me, I`v always got time to do it twice
                            • #44
                              Does anyone know where to get a puller at?
                              Also how come it's not safe to just add a new valve on the old nut and ferrell? I'm just curious.
                              Proud To Be Union!!
                              • #45
                                Also how come it's not safe to just add a new valve on the old nut and ferrel? I'm just curious.
                                You can get a puller at most supply houses and I have seen them at Lowes and Home Depot.
                                I'm not really sure why it wouldn't be safe to reuse the same nut and ferrule if they are in good condition. I have done it hundreds of times -- I hope I haven't been doing it wrong all this time. Sometimes it is just necessary to replace the nut and/or the ferrule due to distortion of the pipe, ferrule or condition of the nut. Also, some of the older compression valves have different threads than the new valves and the nut won't screw on properly.
                                Bruce
