Commercial job
    Re: Commercial job
    [quote=plumbdog10;98587]
    in the middle picture, what did you coat the top half of the pipe with?
    why?
    why bell and spigot and not no-hub?
    just curiosity.
    rick.[/QUOTE
    Rick,
    He appears to be working on a College, so I assume it was in his specs.
    I'm with westcoast, the line should be tested before backfill and concrete. If it is running inside of the building a test would be required prior to backfill in California. If it is a storm sewer located outside of the puilding it normally does not require a test, although some juristictions require it. Grade on a large storm sewer is normally set by the civil engineer who provides invert elevations at various points, such as manholes, catch basins and lateral tie-ins.
    Right on the money we have elevation at various points which makes our job really easy.
    I should have stated that we did test the line before the concrete and backfill, we just tied another line in a few days later and failed the complete line test.
      Re: Commercial job
      Originally posted by HVAC HAWK View Post
      my problem is with the OSHA approved ladder
      how do you get away with that
      lol It has feet you just can't see them in that picture.
        Re: Commercial job
        Now thats a good looking ditch,nice to run pipe on something that's dug properly.
        Can you elaborate on the leak,maybe when you find it
        Something like that would ruin my month
        Some nice looking pipe though,how's your back
        good luck on the leak.
        Welcome to the forum
        Thanks My back really started hurting when the 24" insulated chill water pipe arrived and the ductile is soon to follow.
          Re: Commercial job
          I wonder if it separated while backfilling.Looks like it's time for someone to do a Spielberg.
          My guess is the 45 that is right under 4 feet on concrete but thats just a guess at this point
            Re: Commercial job
            why?
            just curiosity.
            rick.[/QUOTE
            Rick,
            Don't they still have to ball and video outside the property lines
              Re: Commercial job
              Sounds like a camera would be an excellent tool right now, you can see if a fitting was displaced while re-compaction of the spoil.
              This will happen sometimes when the pipe isn't shaded properly and compacted properly.
              Good luck, thanks for getting back to us, let us know what caused the test to fail.
              Robert
                Re: Commercial job
                UMM....YEAHHH....I'm with Robert on this one.
                HE-HE-HE
                • #23
                  Re: Commercial job
                  HE-HE-HE
                  Ummmmm, yeahhhhhh, I am with adam on this one
                  Robert
                  • #24
                    Re: Commercial job
                    Here are some pictures of some more rainwater we did this week. The civil engineer counted every floor on the parking deck as the roof so we have plenty of drainage.
                    Mostly 8" CI with a 4" for a clean out in the pictures. The pipe in the last picture was straightened before we back filled.
                    • #25
                      Re: Commercial job
                      Also one of use backfilling.
                      • #26
                        Re: Commercial job
                        Good job, glad you told us about the last picture, I am sure we would have caught that, you know us well already
                        Did or have you found the cause of the other leak? If so, did you re-dig, camera??
                        Thanks again!
                        Robert
                        • #27
                          Re: Commercial job
                          I really wish we had a camera, lol my company really does not like to buy anything like that so we rent everything.
                          As for the leak my guess at this point is the pipe itself has a small hole in it some were. We have been finding pieces with all types of defects recently. It seems this pipe is not as good as charlotte pipe which we have used in the past.
                          • #28
                            Re: Commercial job
                            errr, that sucks if it has a hole, nothing worse then getting defective material. It's one thing to have a co worker mess up, but it's way worse to have defective material from a supply house.....
                            Robert
                            • #29
                              Re: Commercial job
                              15 years ago we looked for two days for a leak in a gas system in a new custom home under cunstruction.Soaped every thread connection multiple times.It ended up being a length of korean pipe who's seam had pinholes every few inches down the run of that section of pipe
                              • #30
                                Re: Commercial job
                                nice work man i was just wondering if that ditch ladder was big enuff?
