The use of a Plumb Bob?!
    Re: The use of a Plumb Bob?!
    I am seriously interested in learning the advatages and techniques of the folding rule.A senior tradesman told me to get one.
    Oh ****,I just thought of one after you got me using my head after all these years of not having one.
    Up on the six footer and you gotta find out how much to cut off your hockey stick to make an offset from the hole to the pipe below...unfold 6 inches and stick it up in place...one hand.
      O.K.I'm ignornt,what's a hockey stick.I cannot find it anywhere in the UPC.Oh,it must be in you jurisdictions code
      No really,I have no idea what you are trying to teach me.
        Gunner, find that in UPC.
        Hockey stick, must be a local term.
        When you have copper in a tight spot, like around a PVC drain and ya don't feel like messin' with heat shields, you prefab a "Hockey stick" and slide it in place.
        Get it?
        Gunner is slang for a piece of pipe either dry-fitted or put in place to size/measure, in case you guys don't use that term either.
          Duck, do you also have pop in your icebox?
          Thanks for the East coast-to-English dictionary.
          I love my plumber
          "My Hero"
          Welcome, Phoebe Jacqueline!
            Get it?
            Gunner?,as soon as you cross the mississippi you can call it a shooter.
            Just kidding,I have only heard myself call em that.
            Hockey stick,dunno.I'm lost,but you guys are used to that by now,all it takes is for me to think about it
              Learn the art of using a plumb bob, then put it away next to the old star bits.
              Get a self leveling laser to become a quick an accurate professional...
              The best time saving invention since the boom lift...
                Unless your working off a boom lift.
                You better have a plumb-bob to work off snap lines.I don't want to pay a guy to up and down all day moving his laser.
                I do like having both.
                Just figured it out.Let err rip gfezz.
                Plumb-bob is now for ground work only
                • #23
                  ita a great way to make sure the jambs on prehung doors are plumb. just hang it from head jamb and adjust vertical jambs untill all distances to jambs are equal. saw norm and tom sikva do this on TOH. it works very well.
                  • #24
                    That's what I'm saying.It always makes me laugh when a plumber tries and come up with references how his plumb-bob has it's origin based on the plumbing industry.
                    • #25
                      Learn to use a builder's square, a folding rule will come to you. You can layout any plumbing angle with a square. Educate yourselves.
                      the dog
                      • #26
                        you can also chuck it at your apprentices's head when he pisses you off Seriously though, use one all the time for lining up the vertical stack penetation through the roof. Also need to attach it to the tansit so the transit gets set over the bench mark. Don't use a transit? If you're doing any under slab at all a medium priced transit or builders level and a quick read of the manual will save all kinds of time. Hate most of the cheaper lazer levels, the beam gets lost in bright sunlight
                        • #27
                          Welcome to the forum NHMaster.
