Submersible Pump does not stop
  • Submersible Pump does not stop
    Hello,
    i have submersible pump in my basement
    Sumbersible pump is working, it pumps out the sump but it does not stop working after doing so.
    hence air starts going in and i hear bubble sound.
    right now i have to unplug the pump.
    i looked for a float valve, thinking it might have got stuck
    but i realized this one has got a diaphram switch, which works on pressure sensor and does not get stuck.
    please let me know, what should i do to resolve my problem.
    thanks,
    avani
    Re: Submersible Pump does not stop
    Hello, it is called a diaphragm switch and it needs to be replaced, once that is done, the pump will turn off and on properly without unplugging it.
    Robert
      Avin You're an Eng. and You couldn't fix that? Makes sense to Me
        I'm a nuclear physicist
          Don't get Me started on Engs.
