Pressure testing residential gas systems
  • #61
    Re: Pressure testing residential gas systems
    I usually test mine at 12 psi, then the inspector can kick it down a couple pounds if he wishes.
    the code requires (upc) 319.0 10 psi test or less should be performed with guages of 1 / 10 pound incrementation or less.
    of course med and high pressure tests have different guages, this is just for low pressure, 1/2 lb test.
    Robert
    • #62
      20# for 24 hours on a 30# gauge . That what Baltimore county wants and every county is different.
      • #63
        How much pressure change have you seen from temp change? With C.S.S.T ? just lost 2 lbs in 67 hours did this line back on Saturday 90% runs thru a crawl space ?
