Residential Roughing/Finish Preferences
  • Residential Roughing/Finish Preferences
    When you rough/finish a new home/renovation:
    What do you like/use?
    (i had this post set up chart like (so it was easier to read) - but spaces were erased)
    Item: My Answers No Budget
    Drainage type PVC CI verticals
    Water pipe type Copper M Copper L
    Gas Pipe type Wardflex ?
    Tub/Shwr valves Moen Posi-Temp ? Grohe
    Body sprays /volume controls/ Hand held sprayers Ondine Rohl
    Shower pans Musty ? Fiberglass
    1/2/3 Pc. fiberglass tub/shwr Sterling ?
    Tubs Americast Cast Iron wide
    Tub drains Kindred PVC tip toe PVC cable drain
    Whirlpool ? Kohler ?
    Water heater Takagi Mobius ? indirect w/h
    wash. mach. pan or flr. drn. floor drain ? fiberglass flr. drn.
    Boiler Weil McClain ? a new wall hung
    Toilets Gerber Toto w/ $1000 seat
    Pedestals ? American Standard ? Kohler
    Faucets Symmons ? Grohe
    Stainless Steel kitchen sink ? 8" deep Elkay
    Basket Strainer Duo Specification ? Kohler
    Hose bib B&G 1/4 turn Moen H & C model
    Finishes Chrome Oil Rubbed Bronze
    Re: Residential Roughing/Finish Preferences
    Drainage type PVC CI verticals ABS, cast on second stories if customer pays for it
    Water pipe type Copper M Copper L type L copper only
    Gas Pipe type Wardflex ? Galv steel or tracpipe
    Tub/Shwr valves Moen Posi-Temp ? Grohe Kohler/ symmons/kallista
    Body sprays /volume controls/ Hand held sprayers Ondine Rohl Speakman
    Shower pans Musty ? Fiberglass hot mop/ tile is best
    Tubs Americast Cast Iron wide Americast or kohler cast iron
    Tub drains Kindred PVC tip toe PVC cable drain ABS tip toe
    Whirlpool ? Kohler ? Kohler
    Water heater Takagi Mobius ? indirect w/h Bradford white/ rinnai tankless
    Toilets Gerber Toto w/ $1000 seat Kohler cimarron
    Pedestals ? American Standard ? Kohler Kohler fixtures
    Faucets Symmons ? Grohe Kohler
    Stainless Steel kitchen sink ? 8" deep Elkay Franke
    Basket Strainer Duo Specification ? Kohler Pro Flow or kohler
    Chrome/ brushed nickle
    My answers are all in red
    Robert
      Pretty much what Robert said except for the tip toe drain (YUCK)
        I like PVC waste better than ABS.Cast overhead.
        Ive never done a job where I picked out the fixtures and I don't fix'm.
        Just have your interior designer fax me her selection.
          Robert,
          i used to like ABS more at 1 time also - thought there was less of a chance for leaks & can fix leaks w/ a hot screwdriver,but dont really like the summer banana effect though
          now im more into PVC - low chance of leaks also as long as every joint primed & glued correctly
          + psychological research states when people see white they think clean (as in why doctors & nurses wear white coats in hospitals)
          i especially cant stand seeing ABS traps in cabinets/vanities
          although, the 10 bath house we're roughing now will be done all in PVC foam core, the roof penetrations will be ABS (transitioned w/ some green glue)
          why do you use galvanized gas pipe in a house?
          does it have a longer life expectancy like L copper compared to M?
          Kallista valves & Franke sinks are nice?
          thanks for responses
          eric
            If people were willing to put in access panels trip lever tub waste are nicer.But for now its tip toe.Plus it's easier for Homer to maintain.
              Robert,
              eric
              Kallista fixtures and Franke sinks are excellent, as long as the customers wanna pay for the quality. I never go anything less then kohler on residential and symmons on commercial or rental units.
              I love galv for gas because you can use it looks cleaner and is rust resistent, I can use it ouside, above ground and inside also, less fittings and nipples to carry on my van.
              My fellow plumbers back east say it is bad because it flakes, I never have had that problem, it isn't a concern out here, and code approves the use of galv for gas here.
              Between you and me, I think we have better gas here in the west
              Robert
                u dont like the cable drains as opposed to the trip levers?
                some r pretty nice
                  Excellent point Adam, an access panel is needed for slip joint w/o's, I think tip toe is nice, they have to be adjusted right
                  Robert
                    I don't think you can use it Eric.You got bad gas.
                      Of course if you use brass ferrules on the W&O instead of slip-joint washers you don't need access panels.
                        Right...They have to be adjusted
                          All seriousness why have I never heard this before.I thought it was due to mechanical joints.Why would the brass ferrule alter the application.
                            They are consider a permanent joint which never need maintanance unlike rubber or plastic slip-joint washers which need to be replaced on occassion.
                              Mark,
                              That is a very large piece of information,I thank you very much.Ferrules are so easy to be had.
                              I do appreciate this Mark
                              I'll buy your ammo for the trap festival
                              Adam
